VO5
Anyone in here still doing it ?
Any merit in it nowadays ?
Misspelt....sorry...meant Scandalising...:encouragement:
Did it in RYA practical course and since on two of my own boats including current one. Seems in a bit of a blow the wind still can make use of the crumpled sail to some extent but it's definitely easier and quicker than dropping the whole sail and as Seajet says it's quick to revert back to normality. Good for single handed sailing.
Thank you for posting the question. I've been trying to remember the name of it since my RYA course!
Happy to report that I use the technique a lot. Generally when sailing onto the anchor. Furl headsail, spill and fill main to slow down, Drop anchor, nip up the topping lift. Let boat settle on to a suitable transit. Finish by dropping and tidying main.
Hoist anchor ball, put on kettle!
Hello Chris,
but to complete the show, for the bedazzlement of onlookers, all done with bosun's call....proper...you know..![]()
I believe this is the approved technique when picking up a MOB under sail.
Yes, occasionally, if needed. Just as very occasionally you might need to sail backwards.Anyone in here still doing it ?
I do it when sailing off the anchor if it is windy. It reduces the drive from the main so it lessens the tendency to shear from side to side.
I am usually single handed and have to be up front to lift the anchor.
The main had full length battens i do not know if that makes a difference.
