Save The 05:30 Radio 4 Theme......!!
Almost as important a change is that the forecast will be at 0520, not at approx 0536 as before, a small but quite significant difference to me as I like every single second of sleep...
To all those on this thread that wish to do away with the theme, why not just set your alarms to when the forecast start. Therefore, you see, you don't have to listen to it.
If you therefore say you might miss some of the forecast that will be exactly the reason for keeping the theme, you see, it leads you gently into the day/ forecast/ whatever....
If the theme has to go then we are all going to trying to set alarms for exactly the right time....and missing some of it I suspect.... /forums/images/graemlins/mad.gif
I did not actually realise that 5.30 was a real time,I thought those numbers were on the clock face to fill in the gap from when I go to bed until I get up (earliest 8 am, when the next day starts,,,( do people really wake that early??)
