satin finish above and below decks
All_at_Sea
3 Aug 2005
Hampshire
What do you use, l've sanded down the woodwork and would like a satin finish, what do people recommend?
On the outside l have teak strakes, again what would you recommend?
On the rubbing strakes, I just use basic Teak Oil. On the inside finish, B&Q satin finish yacht varnish.
I have recently finished the forward cabin and most of the main cabin. Original finish was a two pack sprayed lacquer/varnish.
I use the same satin varnish on the outside cabin rails.
Inside Ronseal satin, or if you like spending money and extra work, Epifanes rubbed. Outside Sikkens Novatec/top or the latest porous finish from International called Woodskin.
.... l've sanded down the woodwork and would like a satin finish, what do people recommend? ....
Inside Ronseal satin, ....
I have been sanding down gloss varnish on the inside and applying Ronseal Matt varnish over the sanded gloss. It has come up very well, more satin than flat matt, but not much more: 2 layers on good gloss, 4 where I had to prepare back to bare wood on some panels.
I have used Ronseal Hardwood Furniture Stain, (Clear natural matt) for the last few seasons. The clear stain brings out the colour of the teak, doesn't peel or bubble like varnish. Just a light sand down & re-apply another coat when needed.
It is with great regret that we have to announce that VARNOL will cease production shortly. This is due to Norway no longer producing the base ingredient.
