satellite tv
charles_reed
29 Jun 2001
I know of at least 6 people in Gelves, and several others on my way up the W Med who were using satellite dishes with total success.
The dishes were invariably mounted ashore or on the pontoon - boat movement causes far to much loss of signal.
I would have thought that you would only need to use a satellite tracking dish if you inteded to view TV under way (as Inmarsat).
stefan_r
Southampton & Greece (Chios)
athito.home.services.spaces.live.com
Glomex
Glomex are bringing out a new satellite dish that can be used while (gently) underway. I has the gyro auto lockon and all that gubbins.
It is being released in the UK at the boat show and will be about £600 including decoder (decoders are about £300 anyway).
I have a PDF of the specs somewhere but if it works this is what I am going to go for....dimensions are about 500mmx600mm high if I remember right.
mailto: stefan@athito.com
ccscott49
7 Sep 2001
Re: Glomex
Let me know what you can find out about it, I'll have a lok at it at the boat show, but 600 squids is a lot of money still!
As a point of interest I can mention that I have used a satellite dish (large) fixed mounted on my charter yacht in Norway with complete success. Admittedly I moor alongside at the same spot as I come and go with my charter parties, but still, I find the directional stability of the signal quite flexible. I bought a handy little gadget you hook up between the antennae cable and the dish to tune the signal visually as well as audiably.
I remember with amusement some years ago fitting a small TV antennae to the tiller which had a small autopilot fitted. When at anchor, I just set the course in the direction of the strongest TV signal and the autopilot did the rest, swingeing with the tide.
Sinbad the Sailor
ccscott49
7 Sep 2001
Re: Glomex
Didn't see anything at the show, apart from very expensive, but a can confirm a 30cm dish is too small for spain, you need a 60cm one, which works fine! The dishes are cheap enough! About 25 euros down there.
