roaringgirl
My friend's boat has 2 alternators, one big balmar for the house bank, one smaller one for the engine start bank.
Problem: the *only* draw on the start battery is the starter motor; once the engine has been running for 10 mins, the start battery is full, the small alternator output drops to 0 and the "alternator not charging" alarm starts beeping.
Solution: I wired in a relay, switched by the ignition feed, which turns on the engine-room blower (and a small light bulb), both powered by the start battery - this way there's always a small drain on the start battery when the engine is running, and the alternator will always output a bit and the alarm will be silent.
Can anyone see a problem with this? I just need a sanity check.
