cyberpunx
Hi there all with regards to my motorboat Angelica which was sunk on wednesday morning i have now recovered her from the seabed. thanks to all who gave time and advise to me on recovering her i would like to thanks each and every one of you.
so a BIG thanks next on the agenda is salvaging the petrol engine im sure it's a volvo penta 105 petrol engine whats the best thing to do straight away to the engine? i got some advise on it if there is any mechanics out there who could point me in the right direction . here's what ive been advised so far :
The important thing to remember is that the moment the engine surfaces the
clock starts ticking in terms of getting the engine running.
Here is a suggested approach to sorting out the engine.
Drain carbs then remove the spark plugs
and spin the engine over to clear water from the cylinders. Drain the engine
oil and replace. Once the engine has been spun over to clear the water spray
inside the bores with WD40 or diesel and leave in while you dry out the
alternator and other electrics. You may have to strip down the starter motor
and dry it first but the important thing is to get the engine running as
quickly as possible where its own heat will dry it out. If you can before you
start hose it all down with fresh water to get rid of the salt. Use loads of
wd40 to spray all over the engine and electrics ( you will be surprised how effective it is).
Thanks for that info (you know who you are)
so any further advise appreciated and again THANKS to you all it really did make me feel better. I cant believe how bad i actually felt honest i was amazed how bad i felt.
anyway there's a pint at the bar for you all.
regards John
regards John
