thesaintlyone
Need to install a tap for the Saltwater inlet in the Galley what options are out there only seen the Whale Flipper and Whale V-Pump Just exploring other options that maybe out there
Regards
Regards
There was a Whale foot Pump attached to the fresh water tank so I am thinking this may of been a conversion and its now surplus as I will likely install a mechanical pump whats the arrangement from the inlet seacock to the foot pump to the tap and what tap options do I have for Taps using the foot pump
Think I'm gonna try re-fitting the whale footpump and connect a shower type head that can be pulled out for rinsing etc
No need for a tap. You just need a faucet at the sink as water only flows when you pump.
Old B, why do you need a faucet in you installation? Surely the water will only flow when you pump.
That's why you use a faucet,.
Or in English a spout.
faucet is American
According to OED, faucet = tap. A water outlet with no control is a spout.That's why you use a faucet, not a tap.
