elenya
Hi
We own a Saga 40, Elenya, and have had her for about 20 years. You can see some of the sailing we have done on her at www.yachtelenya.blogspot.com.
With regard sailing the design is not slow off the wind. Yes we tend to sail in areas with lots of wind but even on light days we manage ok. Average speeds for us would be 6 knots over most of our passages. We can sail happily at 8, had her up to 12 and spent many hours going nowhere. This is all ‘off the wind’ by which I mean a close reach or further off the wind. Close hauled we will slow to 5 and tack through about 90 degrees, and make reasonable leeway.
The rig is low aspect ratio so does not have a massive high wing shape drive of most modern boats but this does help to keep sail area low. Off wind the mast height is less important. The cutter rig is great.
Light wind performance is not sparking but again off the wind the displacement helps cary way in flukey light winds. Good sail shape helps and once she is in a groove she keeps on going.
Sailing two up in the areas we sail having a seaworthy bullet proof design that can easily look after us suits us. I would go for a test sail or try a similar style of boat before you buy.
Everyone who has sailed with us is impressed with her performance off the wind. Even our friend with his sunfast 36 could not believe it when we accelerated away from him down wind in light airs.
Do not forget this boat is only 32 feet on the waterline.
Hope this helps
Regards
Hope this helps
Regards
