Simon helene
Hi , I've had last year a lick from very likely the beginning of the exhaust tube.
When engine is running the water never enter ,when it stops slowly passes inside the gear box so in the next morning I get out from yhe oil pump like 1,5 l.
But I've done 200 nm in this condition every day removing oily water and adding fresh oil.
When I understand this problem was a few days I didn't check the oil level , so I just get a girl on the bus stop, and I wanted to bring her to city instead of the bus .
Was some days I need to use many time the key to start it , didn't go at ones . Do I was pushing too much battery take fire ... and she loses the bus jajaja.
So then I checked the oil level and was a grey salty mix almost coming out from the engine.
I've cleaned as much as I could ,take all out clean whith diesel , but the fly wheel got affected whith rust and now is hard to start .
Should I take out the engine and make it re check all?
