WilliamUK
Hi folks, as some of you will have seen, I have a boat which needs a bit of TLC before she goes back on the water.
She was sailed on salt water and then laid up for a while before I got her and so there's a fair bit of salt in the works. The cleats vary between "seems OK" and "almost solid with salt".
The two main types are the normal cam cleats (two cam-shaped things that jam a line between them) and something like this: http://www.sailboats.co.uk/productinfo.aspx?productID=R3591
I don't mind taking things apart if they don't need specialist tools to reassemble, and as there are bigger jobs (like a hole in the deck) that I'm waiting for a chance to start I don't mind taking my time on the smaller jobs to get things working as well and smoothly as possible.
That said, what's the best way to go about servicing these things? I need to get the salt out of them for sure, but is there anything else that may need doing? Spring replacement, lubrication or anything like that?
I've had a good ol' search on google and haven't found anything worthwhile yet so I'm hoping someone can point me in the right direction or tell me what I need to know.
Cheers.
Cheers.
