Balticfly
Active Member
Any tips? I will be singlehanding a basic boat. What equipment? How long will it take? Best route? And any other help please
I've been giving the fridge some though! This is the first boat I've owned with a fridge and I am experimenting with how long stuff can keep frozen then cool in it without the use of power. To date I've had things last five days. Everything goes on the fridge frozen, milk, bread the works (stuff can be quickly thawed out if placed in a bucket of salt water as long as it is well sealed - soggy bread is no fun at all). I have a once a day opening routine and back fill with insulating material. Does anybody else to this?
We freeze all the bread at home and take what we need from the freezer, it keeps longer. Freezing UHT milk does sound silly but we are using it to keep the other stuff cool. The other thing we do is pre-pack everything in portion size chunks, e.g. 2 slices of bacon 2 sausages, while it is a pain sorting out food for a trip and uses a lot of plastic it allows us to cook exactly what we need.
Much easier with you can pop everything in a freezer box and drive an hour down the A38.Sounds sensible - alas home to our boat is via EasyJet or Ryanair
Decent self steering if you can but if it's a small boat with a tiller then a spare tillerpilot is very cheap - just make sure you have two separate leads from the battery so you have full redundancy.
Personally if you can't afford it then AIS and radar are very optional as you probably won't hit anything and probably won't be hit and that's the way it's been done for many decades - once you are away from shore. For battery consumption and expense I'd avoid a fridge too although I wouldn't live without one on a boat myself. Cheap solar panels and a controller if you can afford it and are doing this long term - otherwise far cheaper and simpler to stack up with a lot of jerry cans, maybe 10 x 20l depending on your initial tank size, and ensure you have a good way to fill your tank in rough weather - I use a squeezee ball primed siphon from ebay.
And otherwise it's non-perishable food after the first few days - some easy to cook, some much nicer but deliberately more complex as that will pass the time. Lots of basic tools and spares and a bit of practice.
Personal safety equipment - is there any point at all in a lifejacket or harnessing up if you'd only be dragged alongside the boat or be left watching it sail away?
Have you done much single handing? What boat?
Best read is probably this one - http://sfbaysss.org/main/resources/
