Ripster
Changed the oil in my D130 leg in Dec (used 15-40 as I have always done) after 2 seasons of use. No water ingress and the oil looked as clean as new. It had done about 120hrs.
Went into Volspec at Tolesbury today & asked. it was clear that different saildrives have different oils ie engine oil or ATF so it probably means that we are all correct if we are referring to our own saildrive. there was one saildrive ( forget number) which has a special gear oil but hey! its not mine.As VicS says, this is the reverse of Volvo's advice as of about year ago. For instance, the 120S range of legs all specified engine oil, except for the 120SE which used ATF; Volvo said recently that even this one could now use engine oil.
Perhaps someone should call Volspec and query their advice.
Went into Volspec at Tolesbury today & asked. ------------ you can all argue as much as you like- i am OK:encouragement::encouragement:
