saildrive anode on etap26
pcleary
25 Feb 2009
how can i find out what saildrive is on my etap26 1983 and what anode do i use ---is it just an allen key to remove the propeller
Tranona
10 Nov 2007
The saildrive (if it is original) is a 110 model with a one piece collar anode. Standard Volvo fitment. Allen key to undo locking bolt, then undo cone. Prop should slide off but may need a bit of persuasion if it has not been off for some time. Anode also held on by socket screws. When re-assembling use loctite on the prop locking bolt or better still use a new bolt.
Tranona
10 Nov 2007
Socket screw needs an allen key (as opposed to a hex head that needs a spanner). The locking bolt will need a lot of shifting.
