Sailbot - robotic sailboat
Interesting story about a race across the Atlantic by unmanned robotic sailboats.
I assumed these things would be a meter or two long, but this entry will be 5.5 m.
http://www.vancouversun.com/technol...boat+first+cross+Atlantic/10745954/story.html
I see that Dingle is "an island off the coast of Ireland".. Who knew?
Also that "The boat can sail at a speed of 10 knots". A 5 metre boat?
But. "One of the biggest worries is weather — hitting really bad weather and having damage to the boat and also hitting obstacles like icebergs and boats and other things,” is not reassuring.
Yeah. Obstacles like 8-12 metre GRP boats without ais transmitters.. Crunch..
My thoughts as well, but the route is not on the typical path for most cruising boats crossing the Atlantic.
Ah... The eternal optimism of youth methinks...
Do you think so? In some ways, building and programming a sailboat to make its way across the ocean should not be overly difficult. With GPS, wind instruments, autopilot and weather information from a satellite, it should be able to do the sailing bit very easily.
If it were me, I would make sure there was a computer on board with routing software, get the system to download new GRIB files every 12 or 24 hours and run a new optimum route to the finish line. Then sail that route. Pretty easy.
I suspect the biggest problem is failures of physical systems. If a reefing system jammed and a storm came up, the sails could get shredded. A piece of plastic on the rudder could overload the autopilot and burn out the motor.
I hope there is a follow-up to this because it would be very interesting to see what happens in the end.
