Sail dying
tarik
27 Mar 2004
Broadstairs Kent
Morning all,
I have an old sail which is serviceable but rust marked etc. Is it possible to dye it a different colour (Orange) and if so how much?
As ever many thanks for all replies.
David
If the sail is a synthetic material eg Terylene, Dacron etc you are unlikely to be able to dye it. If it is cotton then you will be able to dye it.
+1
Not tried it but I've been told (by a sailmaker) that oxalic is fine to use on synthetic sailcloth. It certainly removes rust stains on decks etc.
It really does work . Have saved many sails in the past .
I use an old "roasting tray" with oxalic acid solution in . Lay out sail and push tray under affected part . Do bit by bit .
