kalanka
Can anyone help with the following concerning a 1988 S34 with wing keel?:
1) The keel bolts inside the bilges seem to be nutted studs rather than bolts and have little thread protruding above the nut - insufficient for a second nut. Is it possible to draw a keel bolt for inspection without dropping the keel from the boat? No sign of any problems but a check would be nice.
2) I have just replaced an old style tricolour/anchor light at the masthead with an LED version of the same. The old light had a simple positive / negative connection from a cable in the mast but on the switch panel Aux 1 operated the tricolour, Aux 2 the anchor light. The LED light changes from anchor to tricolour by reversing polarity. Is this simple reversal of polarity likely to be what Aux 1 and Aux 2 are already doing from the switch panel? The mast is off the boat at the moment and I am keen to do any new wiring before re-masting. It would be great if Aux 1 and 2 continued to work as before without any additional wiring but this may be too much to hope.
