stuartwineberg
Ok - new impeller, heat exchanger stripped, cleaned and refitted, oil cooler checked (clear), air charge exchanger stripped and cleaned. Thermostat tested and opening OK. Will run all day at 1200 rpm and 8 knots and is at 82 degrees. Take her up to 2100 revs and the temp creeps very slowly up to over 90 (over about 5 minutes) - I havent dared take her higher. Throttle back and within 10-20 seconds temp is back to normal
My guess is now either a worn raw water pump (boat has about 520 hours) or a partial restriction on the raw water inlet. The latter is a pig to get at due to the way the strainers are fitted but that will be my next step. The boat doesnt come out for the winter so cant easily check from the outside. Any other thoughts? The other engine is fine.
