sabb diesel engine ( valve clearance )
watermint
28 Jul 2010
by the sea
hurley-silhouette.blogspot.com
aney one do u no what it cood be ?
i been working on the sabb diesel engine to day and i been looking at the valve clearance of 0.3mm (.012'') , i sorted the inlet valve and then i look at the exhaust valve and i cood not get it a justed to 0.3mm (.012'') and the was still a bit of play and that got me thinking , was the push rod bent or warn down of ues then i look at the ball bearing in the rocker arm and that look good then i went to my garden to look at the other sabb engine for sper parts and it was the same on the exhaust valve exhaust and that got me thinking what cood it be to do this cood it be the cylinder head not be torque lode of nuts : cylinder head nuts mabey not of been torque to 14 kpm, 100 ft.-lbs and i was thinking if it was this mavey the valve clearance cood of been sorted but i am looking in to it ,
! aney iders
s i got a 10hp sabb engnie i took off hed in my garden and did all the vaves and i will take off the hed on the boat what is a 8hp hed and i put the 10hp hed back on to the engnie on the boat ( the 8hp hed need a bit of work dowing to it and the therd is gon wher the glow plug gows ) and i get it fix in cace its needid a gen some time . i will do the copper gasket if it has not deformed from circular by heating over gas stove until red hot then drop into cold water.
my sabb engine in my yacht boat is 72 yers old
it was my grandads boat them my dad boat and now my boat
the sabb was lacking mantenents over 72 yers and now its back in ues and the sabb has had some love and a bethday with some parts from a nother sabb engine :)
! aney iders
Sometimes the rocker arms wear where they contact the top of the valve stem. Because the feeler gauge bridges the wear it gives an incorrect clearance which could be much more than the feeler thickness.
Us old fellas would adjust such tappets by feel without a feeler or using the picking from a cigarette packet. The old ones were just right.
Check your rocker arms.
