duncan99210
Bedford MK 4 tonne trucks (the workhorse of the army for of so many years) all had easystart pumps in the cab. They were for cold starting: you removed the top of the container, put an ether capsule in and replaced the lid. There was a plunger you pushed down to break the seal on the capsule and a small pump which was used to pump the ether into the inlet manifold. Pause a second and crank the engine. However, it was aimed at sub zero starting and the capsules only issued in winter when the weather got cold enough to warrant their use. So ether is a solution which works and used to be designed into engines of the same vintage as the Saab but thinking seems to have changed over the years.
