S/steel rope cutter corrosion
BlueSkyNick
29 Apr 2003
Near a marina, sailing club and pub
I stripped the rope cutter and thoroughly cleaned it - brick cleaner is wonderful stuff (barnacles hate it!).
I was rather surprised by the extent of corrosion inside the rope cutter corresponding to corrosion on the prop shaft. (see pic below)
Both shaft and cutter are 316 stainless steel. so why the corrosion?
sailorman
21 May 2003
Here or thertemp ashore
crevice corrosion ???
did you use a barrier paste
Billjratt
9 Sep 2004
Firth of Clyde
Why is the corrosion area so well defined?
It looks like the (comparitively) unclamped bit is corroding while the tight bit has survived, so we probably don't want any ingress between the surfaces.
I'd pile in the yellow stuff if it were mine. (Duralac!)
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
It's a particularly nice example of crevice corrosion, which I would like to add to my website with your permission. You can see explanation and examples on the site here. You only need to exclude the water to prevent it, so bedding it on a sealant will do the job. Don't use silicone as the acetic acid cure won't help. Polysulphide or polyurethane would be best.
Skysail
30 Sep 2004
Victoria BC
I am curious as to why we don't see this more often on a cutter? There are thousands fitted and its not been noted here before.
vyv_cox
coxeng.co.uk
My guess is that this example doesn't fit the shaft perfectly, whereas mostly they do. If it has been strained, not correctly specified, etc a crevice would be created that will cause the problem. The same corrosion problem can be seen around the two central bolt holes, suggesting that these have been tightly bolted, whereas the other two have no damage. The fitting has therefore not been perfectly aligned.
BlueSkyNick
29 Apr 2003
Vyv, of course you can use the picture - PM me if you would like the original high res version.
thanks for the advice, too.
Love the pic of the keel bolt, glad its not one of mine (he says, touching wood rapidly!)
Neil_Y
28 Oct 2004
Devon
www.h4marine.com
Classic oxygen deprived corrosion, this diagram shows it and the website explains quite well.
fetch.php
You have to remember that 316 is at the very bottom of the corrosion resistant steels.
Another factor to be aware of is if steel is stressed it is more likely to corrode, so over tightening can accelerate corrosion issues. Try the bent nail in salt water that we once did in metalurgy.
