Left one ?
I don’t know your engine but on the d12 the heat exchange has 2 anodes. Remove and screw in a barbed adapter. Simply have it circulating in the bottom and out the top. The heat exchanger is the main thing you are trying to clear
Thanks FARSCO
So as I understand it I need to mix it 50:50 5 litres of each to make about 10 litres in total
Very helpful video , where did you get the rydlyme and the hose adaptors from
Just ordered this for £15
Does it look ok for the job?
Seaflo 01 Series Bilge Pump 1100GPH Submersible Water Pump Yacht Seaflo 01 Series Bilge Pump 1100GPH Submersible Water Pump Yacht: Amazon.co.uk: Sports & Outdoors
Is there an alternative to Rydlyme? I can have the boat taken out of the water (we have a trolley and tractor) so not concerned about marine life.
Thanksthat pump looks fine has a bigger outlet pipe and higher flow than the one i used but thats not a problem, you'll just need a short length of 1-1/8" pipeand you wont need a reducer as thats about the same size as the pipe on the elbow and strainer so you will probably need a piece of 28mm tube and some jubilee clips as coupler
