mickywillis
I've just acquired a secondhand Rutland 503 complete with a 7ft SS mounting pole and a charge regulator.
What I'm trying to find out is should the wind turbine swivel around the pole? The base of the 503 is attached to the pole with a couple of SS screws, but doesn't appear to turn? Which basically means it would face towards the bow of the boat when fitted and will happily face the wind when on the swinging mooring. But when on a pontoon, the turbine would be in a set position and not free to face the wind direction. Is this correct or should the turbine assembly be free to rotate to face the wind?
Ringing Marlec suggested that the 503 is set in a fixed position. But videos online show a 503 free to rotate to face wind when mounted on a pole.
I'm confused as to whether the unit I have has seized at some point and needs freeing off or it should be as is?
