sailingjupiter
Active Member
Following my last post about which shaft seal to go for, I have decided to see if I can remove whats there already first. Its an old stern gland. Will this come apart easily?
There is also the coupling that holds the shaft in place with 4 allen key bolts. I assume these have never moved in the 18 years of the boats life and look well rusted. Any tips on how to get these out. I have read about releasing oil and hitting it with a big hammer!! Obviously I don't want to damge anything. Anyone had a similar problem? how did you undo the things?
Assuming I do get it off would the prop shaft just slide forward so I can put on the new shaft seal and then just reconnect up? New bolts will probably be a good idea. What type, stainless, galvanised etc etc. Engine is a Yanmar 1GM10.
Thanks again for the help.
