ohthetrees
I'm in the middle of dealing with paint failure on my cast iron keel. I'm in Panama, and they don't have sand blasting in this yard, so I'm looking for a "good enough" approach until I can do it right in a more fully equipped yard with proper sand blasting.
More here:
Keel paint failure. Hull is fine. How to proceed? - Cruisers & Sailing Forums
The approach I went with was to grind down to bare metal where ever there was signs of rust or failing paint. There is some texture to the casting (which had been covered with a layer of fairing compound), and some crevices where grinding and wire brushes couldn't get every trace of rust, so I decided to treat with rust converter. The only brand I could find locally here in Panama was Sur Corrostop.
The plan from here is to use a 2 part epoxy primer (5 coats), then underwater primer over that and all the areas of the keel that I didn't grind back, then bottom paint.
The problem is the rust converter. It has left a shiny residue that I'm suspicious of. I'm worried that it will act like a release agent and prevent the epoxy primer from bonding properly to the metal. I've included photos of some drip marks left from the rust converter that illustrate the sort of residue it leaves behind.
What do you think? Am I better off leaving the rust converter in place, or going through some sort of solvent/mechanical process to get it off? Remember this whole thing is supposed to be a stop gap solution for 1-2 seasons until I can do a total redo of the keel with sand blasting equipment.
More here:
