Capt Popeye
Yes I sort of get this argument - and I check the outboard at home with muffs. But, because I'm new to this, it seems feasible that you could test the engine at home with muffs, then drive 50 miles to the coast over bumpy roads, during which time you could damage or dislodge something in the electrical or ignition system, or the battery starts to fade. Then you drop it in the water and it won't start.
Like you lot I probably won't give it a second thought after I've been boating for a few years. But the problem just had me scratching my head a little bit. After 100 years of outboard development, you can still turn a brand new 10 grand motor to scrap by accidentally turning the key?
Humm well thank you tsf you speak wise words I say, my thoughts are that the Manufacturers are 'blind' to the situation, companies run by peoples with grease on their hands, and all is well, a sort of Engine Groupie, so suggest that any improvements are to come from those outside of main stream Outboard Engine Manufacturers.
The RNLI do appear to have given it some thoughts and they have their own way of dealing with this situation, maybe the water pump is lined with a Ceramic material so reducing the rubbing /shear stress on the Impeller blades.
As the response that OB run in water so where is the problem, well partly or even mainly true, but at the Start of a day afloat it is good to start the Engine when the Boat is out of the water, just to see that all is well, good practice I would say; not everyone wants to test it at home or at the garage, or indeed have the facilities to do so; when out on the water and boat is in shallows sometimes the OB touches ground and is tilted up possibly raising the OB water intake out of the water or partly so so the ability to still run the engine safely would be a certain plus.
Still maintain that the underlying reason that OB Manufacturers do not appear to solve this situation is that there is no impitus to do so, yet ?
Oh Air Cooled Outboards I have owned a few, they are just great if one wants the reassurance of being able to start the OB out of the water prior to launching, as regards them being Old Hat or something like that, well yes most probably were made then, but Honda have a current model that's Air Cooled, it may be a little Engine but its Air Cooled for sure.
Lets consider that engines used in Lawn Mowers and Tractors etc are Air Cooled and do they generate lots of noise, well they are certainly more noisy than a Water Cooled OB, but are they really noisy ? I think that a Seagull OB is just as noisy and they have been around a long long time, and they are water cooled .
