ghostlymoron
I just want to be sure i can motor off when lifted in. It's easier to sort out issues ashore as well.
Is this just some vague desire to run the motor or have you some doubt about it running?
It sounds like your boat does not make running the motor ashore easy. So unless there is a big benefit, don't bother.
Running it off load is of limited value anyway.
Can you remove the exhaust and hose water up the skin fitting to prime the impeller pump?
So long as you don't fill the exhaust no damage will be done.
I'd still not trust an impeller to lift water more than a foot or two.
Personally I'd want a strainer of some sort.
But it's nearly august, time it was wet.
