lw395
Oh sure analogies are never perfect and certainly my last paragraph in particular is a considerable oversimplification.
However I think the first part gets over the important point that by discharging a battery more slowly to a given end voltage, you are not increasing its real capacity, you are increasing the depth of discharge relative to nominal capacity (i.e. you are converting a higher proportion of the active material) and the cycle life effect is commensurate. That's the point under discussion here, not recharge efficiency.
There's no such thing as a free lunch.
AIUI, there is inefficiency in discharge too, so the capacity you get out varies according to the rate at which you discharge it.
I get your point that if you take out say 50Ah at 50A, the end voltage will be lower than if you take out 50Ah at 5A. Because the 50A will be causing a significant drop from resistance etc. But if you let the battery settle for a day and then drew 5A in both cases, the battery which had be drained at 50A would generally have a lower voltage than the other.
At the other end of the scale, there is self discharge, so draining a bettery slowly can be inefficient too.
I believe some batteries, drawing a small current can increase the self discharge. I don't know if that's true of lead acid.
