Triassic
Who cares ?
Does the composition of Avgas or whether it float,s or not, have any relevance as to whether, or not, to run a small outboard dry before storing
Yes. If the fuel has water in it then when it eventually evaporates in the tank/fuel lines/carburettor then the moisture may remain and cause corrosion. It it remains separate then any water in the fuel will firstly stop you from starting the engine (the pick up is usually at the bottom of the tank where the water is), so in order to run the engine dry you need clean uncontaminated fuel in the first place......which you then run through the system and drain out by running it dry....
