bedouin
That is rather over complicating things.6 knots is ~3 m/s. For a cargo ship with a 30 m beam, that's 10 seconds to cross side to side, and about a minute to get a cable-length clear. In a narrow channel, where the ship's course is clear, a cable or two away is often sufficient. In open water I'd not want to be anywhere near that close, so assuming I consider a half mile as a "safe" CPA, then that means I'm deciding at least 5 minutes out (more, accounting for closing speeds).
Below is another example, this time for a crossing with perpendicular headings. Note that at ~7 minutes out the distance would be down to 2.5 miles. At that time, to maintain a half mile CPA, you'd need to turn at least 65° (indicated by OsM1 in the third image).
However, these are simple calculations with nice precise numbers. If my idea of the other ship's course was off by 5°, then instead of that 65° turn opening up the CPA, it might return it back to 0! And here's the kicker... while the ship has an aspect of red 17° on course 270, it's only red 12° on course 265. Can you tell that by eye?
View attachment 195770View attachment 195769
It is much simpler to rely on bearings. Constant bearing with range decreasing means you are at risk of collision.
So monitor the bearing of (bow of) the ship from say 10 minutes out. If the bearing is clearly increasing you will cross ahead. Anything else and you are going to want to go round the stern.(let's not play chicken with the big guys). Depending on wind etc I would stand on until say 5 minutes out then turn sufficiently to show my other bow to the ship (or turn parallel to show the stern - technically the more correct action). No need to act any earlier
I am not a particularly experienced sailor when compared to many on this board - I don't claim my approach is superior to anyone else's.
