PabloPicasso
"Ignore and Carry on as before?"
That is what I would do. I tipped a 2ton, long keel, boat once, using an hydraulic jack under the keel. It is not to be taken lightly, I would rather dig the big hole.
If there is no play in the rudder/stock the chances of it dropping off next season are bearable to slim, unless your pal is thinking of an offshore trip. Next winter it could be done at leisure.
If it is a worry you could cut in a couple of windows (as outlined above) and check out the welding of the tangs, shutting up the holes with mat. The problem with trying to split the thing in situ is that you could end up with a right buggeration of bits, with the stock still trapped in the boat.
Ok, given all the variables, opportunities for cock-ups, and likelihood of being worse off with a bodged repair, broken boat, or worse, I'll recommend to the skipper to await the next lift out, remove the rudder then and repair in the heat and warmth of a workshop.
Thanks for all the input, it has helped with the decision making.
