Rudder Stock Cracked.
silverdawn
30 Jan 2005
mountnessing essex
Hi All, Went to fit the newly varnished tiller today and noticed a small crack in the Aluminium stock which bolts
onto the rudder head, the crack is at the weakest point near to the bottom of the 12mm bolt hole I would think it is the original fitting (1984) therefore very hard to obtain a replacement, I dont think a repair would be possible.
I have searched the internet for replacement but failed to get any information most list Dinghy fittings, my boat is a Colvic Countess 28ft I will try the Colvic Owners Association, however can any of you advise where I can buy a replacement or find a local stainless steel fabricator to make one.
I live in Essex my boat on the Blackwater. your advice would be welcome.
Regards Stuart.
PeterWright
23 Aug 2006
Burnham-on-Crouch, UK
The stock of a rudder is the vertical shaft around which it pivots, so I believe you are referring to a crack in the head fitting, which clamps onto the stock, but I may have misunderstood.
Whatever, for any marine stainless fabrication, Mr Stainless (Mark Wingar) at Suffolk Yacht Harbour is a good bet:
http://www.mrstainless.co.uk/
Noting that you're berthed on the Blackwater, you may get APB Engineering in Burnham to do the job:
http://www.apbengineering.co.uk/BOC/service.asp?ccd=apb_engineering
Hope this helps.
nigelm
11 Aug 2008
me - hornchurch , boat - river crouch.
Hi Stuart
My countess has a solid brass fitting which clamps to top of rudder stock , the hole for bolt to attach tiller has worn over the years but I re- drilled/bushed it at work , I would think that if you took your fitting to an engineering co they should be able to fabricate a replacement easily enough .
N
Stork_III
6 Aug 2002
Here and There
If you still need the fitting, I have a friend near Ipswich who has a SS head fitting with tiller for a Countess 28, taken off when he converted to wheel steer. It is available for not a lot. PM me if interested for his contact details. :encouragement:
