Sealong
10m tiller-steering sailing boat.
I have taken out the rudder to inspect the top bearing and lower bush and extracted the lower bush (Delrin, 86 mm OD, 68mm ID) without damaging it. There are salt-like deposits on the rudder stock which I will clean up with fine emery cloth before reassembling the unit.
I would like some advice on what sealant or adhesive to use on the outer diameter of the lower bush which is a loose fit in an aluminium tube that is bonded onto the inside of the hull.
My initial thoughts are to use some sort of Sikaflex, but I am not sure if this will have adequate shear strength.
Any recommendations will be much appreciated.
Chris
Chris
