Rudder bearings and..
TimLamb
30 Sep 2001
Northumberland UK
Comments on the following gratefuly received..
1) replacing the bearings in the rudder stock (Centaur)
2) replacing the rotating wheel which protrudes through the hull on a Nasa Clipper depth/log - one of the four arms having snapped off.
Tim
Tim
There is a whole load of mails in the Westerly Owners group. Do you have access? If not it is highly recommended for Westerly owners if not I will forward you the mails on rudder bearings for Centuars.
(Westerly-owners group on Yahoogroups.com, forget how you join?)
Ken
Hi,
Would you mind showing me where I can access information on the WOA page.
I seem to looking in the wrong pages possibly.
Cheers
Mike
dickh
8 Feb 2002
Suffolk
Nasa Log - I think the pin is just driven out with a pin punch, the new paddle wheel installed and then gently knocked back in again - speak to NASA, they are usually helpful - if you look carefully, I think the pin can only be driven out one way.
dickh
I'd rather be sailing... :)
