Trident
I have stainless steel rudders - both shaft and rudder fin are stainless .
They have always been antifouled and always had anodes attached by a bolt in to the stainless "fin" of the rudder
This year when we lift out they will be stripped back to bare metal and given several coats of epoxy before being antifouled. The rudders should have no metal exposed to water due to the multiple coats of epoxy .
I keep getting conflicted information from "experts" - "316 stainless doesn't need anodes bare or painted" , "you must have anodes even on stainless", "why drill through the protective epoxy to attach an anode to the stainless" etc
Does anyone have a definitive answer ? The only other metal below the water line are the SD20 sail drives in aluminium - also coated with about a dozen coats of underwater epoxy - and the bronze propellors . Oh, also the rudder shoes in to which the shafts sit which are also 316 stainless but I sort of include them in "the rudders" though they do have a phosphor bronze bush inside. All seacocks are plastic, no earth plate etc on the plastic hull
