Rubber drive shaft coupling
The rubber coupling between my gearbox and prop shaft is a Babbitt 406M. The 8mm studs are a bit grawnched, does anybody know where I can get a replacement or something similar.
If you are really stuck look in your yellow pages under 'transmission engineers' look for your nearest Fenner outlet.
Try ASAP Supplies in Beccles.They have a large range of those sort of things. They advertise in PBO.
thanks
Many thanks. Can't look in yellow pages, I'm in Denmark at the moment but I've used ASAP before so I'll try them.
Tranona
10 Nov 2007
Re: thanks
Welcome to the forum.
You have posted a reply to a 15 year old thread so doubt your information will be of much use to the original enquirer.
