Rub rall replacement
rogerthebodger
3 Nov 2001
I fitted rub rails on my ferro boat using Iroko using 2 layers and scarfing the shortish lengths with the scarf joint facing to the aft
First layer was bolted through and glued using Sikaflex and the second layer just glued on using Sikaflex.
I then glued a strip on the top and bottom to seal the joint screwing toe rails and stanchion bases to the top of the rub rails again sealed with Sikaflex.
I then used boiled linseed oil to seal the Iroko
scozzy
4 Sep 2020
Scotland
Thanks all for another educational session 👍 Happily have made contact with a guy who has an abandoned 21ftr of similar vintage in a far flung corner of his property and will be over to his soon to exchange a few beers for the port side rail and dibs on s'board if needed in future!
Happy days
