rogerthebodger
The convertor you have shown should work as I have found from the Starter ring part number followed by an Ebay search this is a 159 teeth starter ring.
This results in a max hz at 3000 RPM of 7,950 hz. The actual engine max speed is 2,700.
I wil need to knock up some simple threaded adaptors for the mount holes which are 3/4 - 18 UNF, with the probe M12. I think I can also get to the tacho probe mount holes on both engines OK. I assume ~ 2mm clearance from the teeth is sufficient.
You would need to adjust the tooth sensor gap so to avoid and interaction with the next tooth on the gear ring dependent on the tooth pitch.
You only need a clearance hole for the sensor as the gap would be adjusted with the 2 locking nuts on the sensor.
