Ubergeekian
If the heads compartment is there, installation of heads is basically purchase of toilet, hoses and sea cocks (£300), cut two holes in hull, make two bearers (if not in heads compartments as built, fit. That sounds like a day's work, maybe two.
Got a quote through to get the heads installation carried-out on the Forth. Here’s what was detailed:
1) Jabsco toilet compact bowl £149.8, or regular bowl £179.75
2) Seacocks and skin fittings £80
3) Other sikaflex, pipes, hose clips £50
4) Labour to fit toilets including seacocks and all fixture & fittings about 12hours (£25 per hour inc. vat)
So that comes in at around £300 for the bits, and £300 for the labour.
Am I good or what?
£600 is well short of £2000, but what about the joinery, headlinings, lighting, sink, taps, sundry hardware items, finishing?
The OP has always been clear that "toilet installation" was to be considered separately from "build heads compartment". Maybe keeping the toilet in the forecabin is an option - you're not a true sailor until you've tried to sleep with straining buttocks six inches from your head. Been there, done that, got the therapist's bills.
