It had been working fine until today.You might just find your halyard is too tight. Try slackening it off until you have just taken the wrinkles out of the sail and try again
Well presumably you adjust your halyard before every sail. No one leaves it under tension all week, because that is the quickest way to ruin a sail. So have you over tensioned it today?It had been working fine until today.
I have to congratulate you one the patronising and sarcastic nature of your post.Well presumably you adjust your halyard before every sail. No one leaves it under tension all week, because that is the quickest way to ruin a sail. So have you over tensioned it today?
Not been up but can see diverted in place and no sign of halyard wrap. It did feel like it was the bottom…It may not be the bottom that is the problem. Have you checked the top to see if the deflector has broken & jammed it, or if you have a halyard wrap, possibly due to a damaged head roller. If you previously had a halyard aligner has it broken free allowing the halyard to engage in the head in some way.
For future reference, if you have problems with it again, Barry the Rigger at Emsworth (google will find...) is the man to go to with rotostay furler problems which can't be DIYed - he worked for them for years, and still has some spares. He refurbed ours on our previous Sadler 29 some years ago, and did an excellent job.Well have taken it apart cleaned it out opened out a plastic bush a small amount. Been out today and as good as new ??
