rotating orange light
ash12
25 Jan 2009
i was looking at an advert for a boat and it said that it came with a rotaing orange light and i dont know what it would be used for. any ideas?
I have one fitted, to be used as a last resort to get the attention of ships getting too close. Not part of lights and shapes except for an air cushion vehicle.
Wouldn't a white hand flare (ie a proper collision warning signal) be a/ more visible and b/ possibly less confusing?
As pointed out a flashing yellow light is the light shown (in addition to the normal navigation lights) by a hovercraft in flight.
rule 23 of the colregs:
(b) An air-cushion vessel when operating in the non-displacement mode shall, in addition to the
lights prescribed in paragraph (a) of this Rule, exhibit an all-round flashing yellow light.
Why on earth would you want to appear to be a hovercraft?
A white flare, or safer perhaps a bright hand held spotlight, would be more effective and the correct method of drawing attention to your presence
Course he could also be a chain driven ferry. But does it really matter.
Don't worry about it, most amber beacons can have different covers readily obtained and fitted, blue, green, red. You can pretend to be anyone you want including EOD (red), Police or Ambulance (blue), Doctor or paramedic (green), you could have real (illegal) fun!
A couple of day trawlers have them fitted down here. Definitely means keep out of the way - I'm trawling. Far easier to spot than a green!
So I agree with above - it is to bring attention to you.
orange lights
Have seen them on JCBs on rock armour barges - bit confusing with a hovercraft. Small pair trawlers use them regularly, but some surface net fishing vessels also use them. There seem to be getting more & more of them, especially at Christmas.
Hi Ash
Paul
Orange flashing
If I'm right a high speed passanger carrying craft or hoverpot is amber flashing at over 60 flashes per minute and a submarine operating on the surface is amber flashing less than 60 flashes per minute. (when not at war of course!!)
Maybe the chap selling the boat is prepared if he submerges a bit!!
Orange flashing Light
Hi
I think you will find Annex 2 of the regs talks of Orange flashing lights on purse siene flshing boats hampered by gear.
Cheers
Two yellow lights vertical flashing alternately to be precise. Looks like the boat in question is not equipped for purse seine fishing.
3. Signals for purse seiners
Vessels engaged in fishing with purse seine gear may exhibit two yellow lights in a vertical line. These
lights shall flash alternately every second and with equal light and occultation duration. These lights may
be exhibited only when the vessel is hampered by its fishing gear
Occultation ! :eek:
"equal light and occultation duration" Isnt that normally called "isophase"?
There have been days when I would have fired off five or six. I think it just gets their attention so they see the fishing signal. As a general rule ships seem to make a point of altering at one mile range, so at three quarters I start considering the options. At fifteen knots that's three minutes and when you have gear over the side that's not much time. Having once been missed by only twenty feet I get twitchy if a ship gets within a half mile. Radio calls are tedious and often don't get an answer, but the beacon has never failed.
