Ropes in the washing machine - what have I done wrong ?
sarabande
6 May 2005
encouraged by the remorseless approach of Spring on Exmoor (two dandelions in flower) I put a loose halyard in a pillow case, and then into a cool wash with a bit of Ecover.
The machine went through the short cycle with a bit of grumbling on the spin section, but when I opened the bag, the rope was tangled, knotted, bended, hitched, entangled, and generally woven into an amorphous lump. But a lot cleaner than when it went in.
Clearly, I have failed to do something to prevent this fibrous failure. Is there a particular prayer, a small libation, even a minor human sacrifice which much be made to the Goddess Irritata (she's the sister to Annoia, BTW) before pressing the ON button again with the next load ?
I have sought in vain a British Standard to give the right technique; should the rope be coiled, wrapped tightly or loose, would extra boaty bits in the washer help smooth the spin cycle ?
TIA
TIA
just rinse, don't spin
In my experience does not matter what you do it still comes out tangled, but worse if you let it spin. Good excuse to crack open a beer and quietly sort it out.
Lay them on the ground in a fairly loose coil then seize the coil 4 or 5 times with 'small stuff'. As others have said, don't spin; as much for the safety of the machine as for the rope.
I found just dipping a few times ina bucket of water and detergent followed by a rinse in clean water gets a lot of dirt out. Just hang to dry good luck olewill
+1
I used the anti crease setting as well because the machine had it. I didn't coil the rope before it went in the machine, just ran it through my hands (to make sure there were no knots) into a pile on the floor and then picked up the pile and dumped it in. To drip dry I looped it over a fence rail in big lazy loops. No pillow case either, the snap shackle was encased in a section of pipe insulation foam tube held with cable ties.
TIA
I just put the rope in the machine still made off as i stow it aboard. no bag just straight in with powder & softener, on a 30 or 40 deg wash with high water level. job done.
clean,soft ropes with some tangles that drop out easily.
i have even done wire/rope halliards too
+1 but i use spin never had them get too tangled
We are a tad further south and have three dandelions in flower.
I did not use the pillow case and spun at 1600 RPM.
A local rigger told me to use the dishwasher, haven't tried it! Can't see SWMBO approving!
no, no, no...dish washer detergents are far to aggressive for ropes.
Washing machine on low temp with non aggressive cleaner such as Stergene (or other wool wash detergent) much better.
Hang on for her to go shoe shopping or something, that is what I do. Gives me hours and hours to listen to loud music, strip winches on the kitchen table, lie on the sofa with the dog, fart and loads of other manly stuff.
Can't quite understand why the OP is washing his lines. Surely it would be cheaper to by some new ones ( Trago Mills? Mole Valley Farmers? eBay? ) than to fork out for a new washing machine.... :eek:
