Amp1ng
Hi all,
Furthering the investigation as to why I have such poor boat speed under engine I have another question this time focusing on the rope cutter I presently have fitted.
This is a scissor type cutter with double fixed blade clamped onto shaft and the non fixed blade with its peg located in a recess on the P bracket mounted plate. Whilst investigating the complete transmission for vibration (which includes Volvo MS2 gearbox spline mod) I am refurbing the rope cutter which needs replacement plastic bearings. When searching through the various makes and models to try and determine which one I have I noticed a recent magazine test on the different types of rope cutter. Reading through I spotted one of the stated drawbacks of the scissor types being loss in boat speed under engine, quoted at 1 - 2 knots. Is this really true?? Does anybody have experience of before and after speeds having fitted one of these type of cutters?
If correct this might explain why I struggle to get more than 4.5 knots from a Volvo Penta 2002 in a Fulmar on a calm day on fresh antifoul. I was expecting 6 knots at cruising engine speeds (2200 RPM).
Any suggestions on boat speed most welcome. Prop is a 15" by 11" LH fixed 2 blade, the exact gearbox reduction ration I'm not sure of, will check tonight but roughly 2:1.
