Rope and wire halyards question
Ardenfour
7 Feb 2004
Port Bannatyne
Woohoo! New boat,can there be any better feeling than the first sail,when you see how she handles, and you explore from stem to stern on a voyage of discovery. Ok, I'm still excited!
Anyway, on my first sail in her from troon to port bannatyne yesterday,where my previous boat had 2 winches,this one's got 7. The foresail halyards are part wire, around a meter of which emerged from the sheave at the bottom of ghe mast when the sail is fully raised. Yesterday led the rope tail to a coachroof winch, which meant the wire/rope splice was under full halyard tension - is it safe to subject the join to this tension? Or should the wire part be round the winch drum? There is a winch on the coachroof a couple of feet from the mast base,but it doesn't look like a wire type drum. Don't know what that's for either. Any suggestions please?
Quite normal for the wire to stop before the winch, and rope only round the winch. Out rope / wire splices were fine for 15 years.
Eventually the rope chafed so we replaced with a cruising dyneema - but did stretch a bit more than the wire (race spec dyneema probably even less stretch, but would have been near £300 which was ruled out)
my last boat had spliced wire halyards, and, like yours, the wire was on the drum when the sail was hoisted, the rope was changed a couple of times due to fraying, but I believe the wire was original (1972). It's quite easy to re-do a splice if it's you who takes it to bits in the first place. (grease helps)
Sorry, I'm being a bit unclear. None of my winches have a drum suitable for wire, i think. I was unsure whether i ought to use the winch at the mast for the wire and rope. The other coaachroof winches are too far for the wire to reach, so i had the rope tail round the winch drum. I was concerned about the splice being under full halyard tension, giving way, and disappearing up the mast. Others suggest the splice should be strong enough. Thanks for all replies
As has been said . . .should be fine . . . the splice should be very near 'full strength'.
Just for the future . . . .if you switch from wire to dyneema, you should (probably) change the sheave, as wire sheaves usually have a quite different groove profile than one best suited for dyneema.
