vasant
Hi,
So this year i spared some time to perform fuel filter change on my own as i consider it vital to familiarize with engine maintenance.
I thought i did my homework pretty well RTFM and checked some youtube posts.
Anyway i changed the primary filter wich i had filled PARTLY with diesel before assmbling and i swapped also the fine filter which i filled completely.
Now the tricky part starts.
After reopening the shutoff valve on the tank i *expected* fuel would run into the primary filter squeezing the air out of the system up to this point. this didnt happen though and i assume that the filter being roughly at the same level of the tank didnt help much. So i started trying to prime on the lift pump but moving the lever didnt do much. Honestly speaking at this phase i hadnt checked in enough detail the manual about the fact that maybe moving the cranckshaft would help to make the pump work. But is felt like i was not pumping anything. It felt far too easy.
Anyway as the pump is not accessible very well i thought it might be a good idea to cranc the engine by hand. Same effect nothing ever happened. I never saw fuel comming out of prime filter.
I am not sure if i just were very unlucky and every time the pump was in the dead point of the cranckshaft or i should be more persistent. I acknowledge that the primary filter has for sure more than 100ml until it would be full, but still i guess that somehow fuel should come through.
any clue on what i am missing?? I would be happy to have a hand pump before the primary filter but the boat lived without it for 30+ years so i guess i am the problem here...
OF course the engine was working fine beforehand.....:ambivalence:
