smeaks
When using in mast furling how is the function of the batters accommodated? And do you have to compromise on sailing performance?
Most in mast mains have no battens and as a consequence the shape of the sail and performance is considerably compromised. There has beeen a move to improve performance by fitting vertical battens but there is a considerable cost to the pocket. Most in mast sails are 20-30% less in area due to their triangular shape and lack of roach.
I'm afraid it will be a cold day in hell before I ever fit in-mast reefing ( if with a larger boat than I now have ) as if anything goes wrong one is even more stuffed than when a roller headsail plays up !
There is also the secondary consideration that it adds weight aloft, and keeps it there when reefed unlike conventional slab on boom reefing.
>Yes, a little less performance, but are you able to notice it?
We've sailed a number of the same make/type charter yachts 80% of them with slab reefing and 20% in mast furling. The drop in performandce with in mast furling is very noticeable due to the flat sail and thus little or no lift. We also had the in mast furling jam on a Jeanneau 52, not a pleasant experience. It wasn't a jam as such something broke at the top of the furler we and had to call out an engineer from the base in Antigua. I wouldn't recommend it.
I can see that worn out flat sails on an old charter boat might not be to your liking.
However, with custom built high quality properly shaped sails I can assure you things are very different.
So if in mast reefing is such a potential problem with jamming etc, what about main reefing out of the mast?
i'm wondering myself if its worth keeping my sailspar main reefing, as opposed to being with this method?
Is boom reefing still considered the way forward?
Well, you are part way there - you just have to go the next step and experience the benefits of in mast furling and then maybe you will be like many others who would never go back.Tranona,
I've tried oysters and like them..
Tranona,
I've tried oysters and like them...
Vara,
yours is the best argument I've seen so far, the bloody boom cover is the bane of my life...however I'll stick with my ball bearing slab reefing system, and worry about in-mast or not when in a position to consider a Rustler 44 or if I'm slumming it a Mystery; no, thinking about it, I couldn't inflict that on as pretty a boat as a Mystery, just call me a luddite.
