Plomong
Type: Facnor C30
Assembly: Upper swivel assembly
Which consists of three principal parts:
- The upper attachment, for the halyard;
- The main body of the unit; and
- The lower plate to which the sail is attached using a shackle. This is the only part of the assembly that does not rotate around the stay extrusion.
The lower plate has a lug with a hole into which the shackle pin is inserted.
Today, when trying to undo the shackle, the head broke off the pin, and it was necessary to remove the sail by cutting away the legs of the shackle.
What remains of the shackle was easily removed from the end of the threaded pin that was not the pin head. The pin did not at any time rotate within the hole in the lower plate attachment lug. It seems to have a fair amount of what looks like galvanic corrosion between pin and wall of the hole.
My questions are:
- Is the hole on this lug threaded ??
- Assuming the hole is not threaded, how can I get the pin out of the hole? Today I tried liberal amounts of WD40, hammer, etc, to no avail. Any other suggestions? Special liquid, etc??
- Assuming the hole is threaded, how can I remove the remains of the pin, which is threaded at least at one end ?
All suggestions and hints gratefully received,
Plomong
My questions are:
Plomong
