Neeves
None of this has anything to do with the anchor type, its not special to Rocna. We were in The Harbour 6 months ago and a crewed charter boat went past with a CQR (probably a copy) inverted on the bow roller. We were doing something critical and going the other way - otherwise I'd have taken a photograph. It happened, before Norman introduced the Forum to his bent link, with our Excel - but no more.
Interestingly Rex Francis from Anchor Right said the same thing when he saw my Boomerang as has been said - that anchors are designed to self right. He also sells bow rollers and replacement rollers - so he is in the right place and ought to know what he is doing. He then reviewed his comments in view of the comments he received from customers - copied the design and sells it. He would not have them in his portfolio if it was an easy issue to overcome some other way. It is a common problem.
But even if an anchor does self right on the bow roller - when you get up in size - having a heavy lump of steel self righting on your bow roller is not a good look - aligning it prior is so much more gentle (and will not damage anything on the bow roller) and needs no human intervention.
Jonathan
Jonathan
