boomerangben
As an addendum to my last……. Perhaps Rocna are in greater need of a new anchor than the market is?
Interesting thought.As an addendum to my last……. Perhaps Rocna are in greater need of a new anchor than the market is?
I think that when Lewmar only supplied the Delta there was a market for upgrading…but with the new Epsilon I am not so sure…unless it turns out worse than a Delta…Lewmar have got the new boat market pretty much sewn up. The fact that anchors don’t ever wear out..and most yotties are stingy…then I agree that the world probably doesn’t need a new anchor.Does the market actually need another anchor? I think it is fair to say that the new generation (and some of the older generation) anchors provide sufficient holding when properly set. Most, if not all new generation anchors are tolerant of poor technique. Is this latest offering just milking a market where people will pay good money to exchange their perfectly adequate anchor for one that is a mark 2?
upmarket motorboats
I think we accept the limitations of our anchoring gear without really thinking about the compromises involved. Having a large swinging circle, being unable to anchor in certain locations (because of poor substrate or inadequate protection), having to escape to marinas or mooring balls in bad weather, the nuisance of swapping anchor design depending in the substrate, deploying multiple anchors and having to extend the scope in the middle of night when an unexpected squall hits are all limitations commonly reported. To many that anchor out infrequently these compromises mean little, but they do matter to a small minority.Does the market actually need another anchor? I think it is fair to say that the new generation (and some of the older generation) anchors provide sufficient holding when properly set. Most, if not all new generation anchors are tolerant of poor technique. Is this latest offering just milking a market where people will pay good money to exchange their perfectly adequate anchor for one that is a mark 2?
The initial information about the Rocna Mk2 showed some very blurry images of a stainless steel prototype anchor. I would now be almost positive that it will be also available in a galvanised version.Perhaps that’s why Rocna’s new anchor is only stainless steel…jewellery for upmarket motorboats
In recent tests, SV Panope has shown that non-rollbar anchors such as the Vulcan and Spade don't work very well in soupy mud, and the rollbar anchors seem to do much better. So if you can get the best of both worlds, why not?
In a thread on CF on the same topic Steve Godwin points out that roll bar anchors, he is specifically testing a Rocna, like ballasted anchors (and Rocna is a roll bar, ballasted anchor) do not do well in soupy mud.
If your anchor is ‘inadequate’...then you need a bigger anchorDoes the market need another, better, anchor?
'We' can surely answer that.
How many have dragged as a result of using a 'new gen' anchor and the dragging was as result of the anchor being inadequate, not bad luck, caught a discarded shopping trolley etc, could only use a short rode (when a longer might have been better).
I don't recall anyone posting that they dragged (or saw someone dragging) using their Rocna, Spade, Excel, Supreme, Knox, Vulcan etc etc. Interestingly though Rocna is commonly reported to lift mud - no-one complains (its recorded as the price to pay for excellence).
Jonathan
Our Spade regularly lifts mud/sand where we anchor. It's also sets really well such that the very powerful windlass with a 1750w motor can't budge it. Once the chain is vertical often we have to motor over it to break it out. I just wish Spade could sort the galvanising problem. Their galvanising is truly awfulDoes the market need another, better, anchor?
Jonathan
Our Rocna has dragged a few times. Generally when holding has been questionable and with sudden wind shifts. I no longer treat 3:1 as the standard scope, I aim for 5:1 if possible.Does the market need another, better, anchor?
Jonathan
In fact the Rocna instruction book says dump out all your chain then reverseOur Rocna has dragged a few times. Generally when holding has been questionable and with sudden wind shifts. I no longer treat 3:1 as the standard scope, I aim for 5:1 if possible.
We've also had some failures to set.
I've come to learn that, despite everybody saying how terrible it is to dump all your chain out too quickly, it's preferable to carefully paying it out as you fall back. The 'careful' method can lead to the anchor skipping along the bottom if you're too slow, and once the anchor builds up speed it's very unlikely to set, IME.
Of course in a pure sand bottom the thing holds like it's glued to the seabed, even on a short scope. But you don't always get that kind of holding.
We've got a 25kg Rocna on 10mm chain, on a 39ft mono. Have used Rocnas for nearly ten years now on two different boats, only began to have problems when we started full time cruising. Of course we spend more time at anchor in one month then we did in a year back home so maybe it's just the sheer number of days that matters.
I find in the Caribbean that most seabeds are sand/grass/broken coral. We modified our anchor setting process some time back. It works well and we get far less issues setting the anchor now. We generally slow the boat head to wind at about 1 to 2 kts depending on how windy it is. The windier it is the faster we can go. We drop the anchor on free drop by releasing the clutch whilst still making forward motion. As soon as the anchor has bottom we turn the wheel hard over and the extra windage of the boat beam on helps pull the chain out of the locker. We run all the chain out to 3 or 4 times the depth of water then fit the snubber. We wait until the boat has stretched out the chain then apply reverse, slowly initially, then increase revs to about 80% of full power. We never drag. Most people never drag but when we do see draggers they seem to be on short scope on CQRs or Delta anchors. We never see new generation anchors drag.Our Rocna has dragged a few times. Generally when holding has been questionable and with sudden wind shifts. I no longer treat 3:1 as the standard scope, I aim for 5:1 if possible.
It has been implied I should not bite to such provocationIf your anchor is ‘inadequate’...then you need a bigger anchor![]()
It has been implied I should not bite to such provocation(as it will result in excommunication) - so excuse me - but like Mr Wilde I can resist anything... except temptation
Sounds like Fraser IslandThe location is wind blown sand, the location is famous for the sand, historically it was mined. Metres thick and built up over thousands of years. Through the sand are channels, creeks, which are now full of soupy mud, prime oyster locations.
Port Stephens, specifically Lemon Tree Passage.Sounds like Fraser Island
