D
Deleted member 478
Guest
I have a rocker switch with an illuminated rocker. There are three prongs labled supply, load & earth. I have used a volt meter to check the continuity between the three prongs.
1: between load & earth there is ALWAYS continuity no matter if the rocker is on or off.
2: there is no continuity between the supply & earth in the off position and there is continuity in the on position
3: there is continuity between supply & load in the on position and none in the off position
Can anyone tell me which prong should have what connected to it. ANYONE that tells me to put the neg onto the earth prong should be ashamed of themselves - that will blow the fuse because there's continuitybetween the earth & load.
John
<A target="_blank" HREF=http://www.stingo.co.uk>http://www.stingo.co.uk</A> - now showing at a computer near you
John
