Sy-Revolution
Hi Folks,
I'm trying to find a holding tank that'll fit in a tight space (300mm max height) and have come across the RM69 tanks.
These look promising because the filler hole is recessed. The problem I have is conflicting information from different sources on dimentions and the lack of 'all round' views.
For instance on the Plastimo site they are shown without an inspection plate and don't show outlets in the underside of the tank but their crap diagram shows just that.
I've seen a photo of the 60l one in an ECS catalogue and that seems to show an outlet at the bottom corner at the oposite end to the filler.
This dimensions diagram shows all three sizes 40/60 & 80l models as being 300mm high:
But on the RM website they show the sizes as:
L x H x W
40l: 350 x 300 x 390mm
50l: 540 x 280 x 390mm
60l: 540 x 340 x 390mm
80l: 730 x 340 x 390mm
But with this diagram, again showing all sizes as 300mm high:
Also they show their tanks with in inspection plate and more outlets on top:
I understand that the Plastimo/ECS tanks are RM69 (or are they?) so what do I believe? What size is the 60l tank and where are the inlet/outlets, also what dia are they? If the 60l in in fact 340mm high I'll have to go for the 50l model, but is it really 280mm high or what?
I'm looking to fit a gravity system and I have the Plastimo electric heads (19mm in 25mm out).
Does anyone have on of these tanks fitted?
Cheers,
Crispin
L x H x W
Cheers,
Crispin
